I am almost embarrassed to say that I have not experienced (yet?) any of the sync. problems that so many people are having. Maybe my stuff is too simple?
What I have problems with is the way many of my document (RTF mostly) come out looking in DTTG: with document sizes that are not the way I set them in DT Pro, and in particular with really wide margins. That is definitely the case of all my documents with tables in them. Now, I don’t know why I keep using DT Pro to make tables because it’s so painful, but after I have finally managed, through a combination of luck and curses, to get DT Pro to size my columns the way I want, it’s kind of annoying to see that DTTG adds a wide margin on the left and then crops on the right instead of scaling. Is there any way to adjust this?
Trying to view things in landscape mode does not help of course because DTTG follows Apple (with their crappy Notes app.) and display on the left side that database navigation pane that I so much wish I could hide. I want to use the full size of the iPad to view my documents, not some GUI elements that I only need every now and then.
