Hello all,
Do Devon agent browser use the safari 3.0 web Kit?
thanks
Hello all,
thanks
DEVONagent makes calls to the WebKit code in OS X. So it will use the version that you have installed.
The initial beta release of Safari 3.0 was somewhat buggy, and I waited to see the experience of others before installing it. I’m still running Safari 2.0.4 (419.3). System Profiler confirms that I’m still running WebKit framework 419.3.
One of these days I’ll be using Safari 3.x. Certainly when I get an iPhone.
Thanks for your explanation Bill.
