Hello,
It seems to be a general concern the optimisation of the general view layout of DT3 (e.g. discussion about the missing three pane view).
I was wondering if it would be possible to find a way to save (favourite) different layouts (the ones the DT3 user utilizes the most) and have an easy way (for instance: via a menu item or shortcuts) to reset them.
For exemple:
For this specific layout view, I’d shortcut as shift+control+1:
For this one, I’d use shift+control+2:
And for this general layout, shift+control+3:
This would mean I could change my viewing preferences, but easily fallback to my favourite ones.
Do you think this (or something similar) could be implemented in the future?
