I’m wondering if the “Scan & Image” functionality is available in the same manner, in case one chooses to index files from the FINDER, instead of importing them into the database. I gathered 3 Question relative to the possible resulting scenari in the following Screenshot:
Scans are currently always imported. One workaround is to scan to an indexed group and to use the contextual/action menu command “Move to external folder” afterwards. This command converts the imported scans to indexed ones.
do you think of a probable reason why the AVISION Scanner does not appear there? (It’s a DEVONthink_Pro-Version – that should work, doesn’t it?)
(-> screenshot)
AVISION answers “No” to the OSX-Image-Capture-Framework-compatibility. The AV176U (Sheet-fed scanner) is dedicated to work (and works) with “ExactSCAN Pro”.
Another scanner (Canon CanoScan 5600F) is available, but this one has no automatic feeder – it’s the reason why I concentrate on the AVISION AV176U, which btw is recommended by ExactCODE (ExactSCAN Pro).
Now, it’s quite hard to automate the whole process, as soon as you want to keep the documents traced/indexed and not imported. As far as I understood, the process could look like this:
OCRed-PDFs are delivered from ExactSCAN Pro into the MAC OSX File System, into…, let’s call it a FINDER-folder.
The interesting FINDER-folders are switched “indexed/monitored” by DEVONthink, in order to keep trace of the added or removed files they contain. That way, DEVONthink administrates the links (paths) to these Hot-Folders.
Be cautious in this line of thinking or you will conclude things that may not be accurate.
DEVONthink doesn’t modify the filesystem (unless an explicit deconsolidate via script / Move to external folder is called). It isn’t even “watching” the filesystem actively. It updates upon selection and is recording absolute paths. Remember, this is a database, not a file manager like Finder is.
Thanks, Christian and Bluefrog for the return of info !
The line “DEVONthink doesn’t modify the filesystem (unless an explicit deconsolidate via script / Move to external folder is called” is deconsolidating me somehow…:
I put a test-file in one of my Hot-Folders (via FINDER), then I went on for the next step in DEVONthink: actualizing/updating the indexed folders with “alt Cmd S” (DEVONthink/Menu/File/Update indexed items). The promt sometimes is avaiable, sometimes not – I didn’t find out why, yet. But I managed to make it work – meaning:
the item appeared in my DEVONthink-UI/Main pane.
after changing the name via DEVONthink-UI/Main pane, the item displayed the corrected name also on FINDER’s side.
the other way around works as well – changing the name of the item on FINDER’s side, changes the item’s name in DEVONthink (well, more precisely, the instance’s name, after updating with “alt Cmd S” (DEVONthink/Menu/File/Update indexed items).
So, did I correctly understand your answer, pointing out, that updates would happen…
either if one makes it happen manually (“alt Cmd S”)
or, second possibility, if a Script is connected to the indexed folder, in order to perform the “alt Cmd S”-prompt automatically, as soon as anything moves in, inside or out of one of the indexed/monitored FINDER’s folders.
Your last conclusion isn’t correct. DEVONthink doesn’t monitor the state of folders and files in the Finder.
You can attach the Synchronize script to an Indexed group. But if new content is added to the external folder corresponding to the group, the database won’t be aware of the change. The script will become effective only when the Indexed group is opened, which triggers the script to update.
Is there any official source for “The Synchronize.scpt” ?
Is there any hidden section of the website here dedicated to DEVONthink-scripts ?
I’ve been browsing around but couldn’t find any reference here, nor in the program-documentation… there is just a few sources online offering the script, but who knows if they are safe…
Bill, the Synchronize script was deprecated in 2.6 as indexed groups are now automatically updated when selected. If the Synchronize script is still attached to an indexed group (pre-2.6 releases of DEVONthink), the ‘synchronize record’ command will be ignored when the script is triggered.
But the point remains, that DEVONthink doesn’t ‘watch’ external folders and immediately update corresponding Indexed items. Indexed groups update on selection.
Search the forum for “script” and you’ll get close to 6,500 hits on that keyword
The installation package for DEVONthink and the package for DEVONagent include standard scripts – the Install Add-Ons… menu is used to install these. Included are scripts to be used from DEVONthink/agent’s scripts menus, and scripts that have a global scope and can be invoked from the system-wide scripts menu
The Support Assistant (Help > Support Assistant) provides additional special-purpose scripts for downloading
External sites such as those operated by Justin Lancey (Veritrope) and Rob Trew (Complex Point) are highly recommended and respected
The DEVONtechnologies blog occasionally posts scripts or links to scripts that Eric has found useful
If you stick with DEVONthink for any length of time – and are interested in using DEVONthink scripts – I advise keeping a safe copy of any scripts that the company produces because from time to time scripts (like the “Synchronize” script) get deprecated and disappear from the release package. Even deprecated scripts can have value and frequently are still functional or make good starting points for your own scripts.
I read about the “Synchronize” Script but could not find any official trace of it anywhere on the site. That’s why I came up with the question for a centralized scripts-repository and asked, if there maybe is such an official place for it.
Here’s the version of the “Synchronize” script that formerly was shipped with DEVONthink, and is now deprecated. (See the conversation up stream of this post.)
-- Synchronize
-- Created by Christian Grunenberg on Oct Fri 22 2004.
-- Copyright (c) 2004-2008. All rights reserved.
on triggered(theRecord)
synchronize record theRecord
end triggered
It’s not useful for its original purpose, now, but it’s a good template for how to make a so-called “triggered” script – a script that is attached to a group or record by means of Tools > Show Info > Script
