Hi, my first post
I’ve noticed differences in PDF quality when I scan with just ScanSnap default settings or when I’m scanning from ScanSnap into DevonThink. The DevonThink file is blurrier and darker.
Example:
imgur.com/Ur7QYkF
(left is ScanSnap-to-DevonThink file, right is ScanSnap default scan file)
Actually I’ve also noticed similar differences between non ScanSnap PDFs when I import them into DevonThink and run an OCR scan with DevonThink. The new file that is made after the DevonThink OCR scan is usually also blurrier and darker.
Any ideas?
Thank you in advance.
