This script creates PDFs for page links and merges them into one PDF afterwards.
The script gets the start URL
- from DEVONthink’s current tab or
- from the selection (i.e. it’s possible to process multiple records at once).
You need to make sure that the start URL contains the string that’s set in property theURL_Query
If something doesn’t work check DEVONthink’s log.
-- Create PDFs from URLs and merge them
property theURL_Query : "?page="
set {theURLs, theRecords} to my getURLsAndRecords()
activate
set theURL_StartPage to (display name editor "Create PDFs from URLs and merge them" info "Start Page:" default answer "0")
set theURL_EndPage to (display name editor "Create PDFs from URLs and merge them" info "End Page:" default answer "9")
set theGroup to display group selector "Choose destination:"
repeat with i from 1 to (count of theURLs)
set thisURL to (item i of theURLs) as string
if thisURL ≠ "" then
if thisURL contains theURL_Query then
set theURL_withoutPage to item 1 of my tid(thisURL, theURL_Query)
set theDate to do shell script "date \"+%Y-%m-%d% %H:%M:%S\""
repeat with j from theURL_StartPage to theURL_EndPage
set thisURL to theURL_withoutPage & theURL_Query & j
set thisRecord to create PDF document from thisURL in theGroup with pagination
set theChildren to search "kind:pdf creationDate>=" & theDate in theGroup
if theChildren ≠ {} then
set theRecord to merge records theChildren in theGroup
set theRecord_Name to (name without extension of theRecord) & space & "[Merged]"
set name of theRecord to theRecord_Name
set URL of theRecord to theURL_withoutPage
display notification theURL_withoutPage subtitle theRecord_Name with title "Merged"
else
my logMessage("No PDF records found", (item i of theRecords))
else
my logMessage("URL does not contain" & space & "\"" & theURL_Query & "\"", (item i of theRecords))
else
my logMessage("No URL", (item i of theRecords))
return
on getURLsAndRecords()
if (exists think window 1) then
set theWindow to think window 1
else
error "Please open a think window"
set theContentRecord to (content record of (current tab of theWindow))
if theContentRecord ≠ missing value then
set theContentRecord_URL to URL of theContentRecord
else
set theContentRecord_URL to missing value
set theCurrentTab_URL to URL of (current tab of theWindow)
if theCurrentTab_URL = "" or theCurrentTab_URL starts with "file:///" then
if theRecords ≠ {} then
set theURLs to URL of selected records
else
error "Please select some records."
else
if theCurrentTab_URL = theContentRecord_URL then
set theURLs to {theCurrentTab_URL}
set theRecords to {theContentRecord}
else
if theCurrentTab_URL does not start with "file:///" then
set theRecords to {missing value}
else
set theURLs to {""}
return {theURLs, theRecords}
activate
if the error_number is not -128 then display alert "Error: Handler \"getURLsAndRecords\"" message error_message as warning
error number -128
end getURLsAndRecords
on tid(theInput, theDelimiter)
set AppleScript's text item delimiters to theDelimiter
if class of theInput = text then
set theOutput to text items of theInput
else if class of theInput = list then
set theOutput to theInput as text
return theOutput
end tid
on logMessage(theLog_Info, theRecord)
set theLog_Info_Prefix to "Script \"Create PDFs from URLs and merge them\": "
if theRecord ≠ missing value then
log message info theLog_Info_Prefix & theLog_Info record theRecord
else
activate
if the error_number is not -128 then display alert "Error: Handler \"logMessage\"" message error_message as warning
error number -128
end logMessage
