I very much appreciate any help or guidance on this.
My goal is to simply run a little script on selected items that batch-copies the NAME field into a newly-created metadata field called “Original Name” or something like that. Thanks in advance!
This is not tested
-- Copy name without extension into custom meta data "Original Name"
if theRecords = {} then error "Please select some records"
set thisName to name without extension of thisRecord
add custom meta data thisName for "Original Name" to thisRecord
return
@pete31 you are amazing!
Stuck that bugger in a new folder called “metadata” on my scripts menu, within DT. It worked like a charm. Thanks a ton! …I can copy this script and repurpose it for similar uses.
Cheers!
Ryan
