This Smart Rule script assigns tags with ignoring punctuation in text.
Intro
Using DEVONthink’s Smart Rule script “Assign tags” it’s possible to assign a tag Hello, world to a record that doesn’t contain the exact tag if you’ve added an alias without punctuation Hello world to the tag:
See Script: Add tag alias without punctuation
Objective
But
I’t not possible with the default “Assign tags” Smart Rule script.
However it is possible with a little setup and these scripts.
This capture shows the result without the usage of an alias:
This capture shows the result when you’ve added an alias without punctuation:
So with a little setup it’s possible to ignore punctuation in both, in tags and in text.
Script 1
This is a Script Library which is necessary as we can’t use AppleScriptObjC directly in Smart Rule scripts, neither embedded nor external.
In Script Editor.app
- create a new document
- paste Script 1
- press ⌘S
- press ⇧⌘G
- paste
~/Library/Script Libraries/DEVONthink - Ignore Punctuation.scpt - press Enter/Return.
-- Script Library - DEVONthink - Ignore Punctuation
-- Save this script in "~/Library/Script Libraries/DEVONthink - Ignore Punctuation.scpt"
use AppleScript version "2.4"
use framework "Foundation"
use scripting additions
on getCharacterSet(theIgnoredPunctuation)
if theIgnoredPunctuation ≠ "" then
set theCharacterSet to current application's NSMutableCharacterSet's alloc()'s init()
theCharacterSet's addCharactersInString:(theIgnoredPunctuation)
else
set theCharacterSet to current application's NSCharacterSet's punctuationCharacterSet()
return theCharacterSet
activate
display alert "Error: Handler \"getCharacterSet\"" message error_message as warning
error number -128
end getCharacterSet
on stripPunctuation(theText, theCharacterSet)
set theString to (current application's NSString's stringWithString:theText)
set theArray to theString's componentsSeparatedByCharactersInSet:(theCharacterSet)
set theString_withoutPunctuation to theArray's componentsJoinedByString:""
return theString_withoutPunctuation as string
activate
display alert "Error: Handler \"stripPunctuation\"" message error_message as warning
error number -128
end stripPunctuation
Script 2
The actual Smart Rule script.
By default all punctuation is ignored.
- If you want to restrict ignored punctuation set property
theIgnoredPunctuationto e.g.",". Don’t include a space, i.e. don’t set", "(or", ;"). This is correct:","(or",;").
Save it to DEVONthink’s Smart Rule folder
~/Library/Application Scripts/com.devon-technologies.think3/Smart Rules/.
-- Smart Rule script - Assign Tags with ignoring punctuation in text
-- Setup, required: Save script "DEVONthink - Ignore Punctuation" in "~/Library/Script Libraries/DEVONthink - Ignore Punctuation.scpt"
-- Setup, optional: By default all punctuation is ignored. If you want to restrict ignored punctuation set property theIgnoredPunctuation to e.g. ",".
-- Don't include a space " " in property theIgnoredPunctuation. Don't do this: ", " (or ", ;"). This is correct: "," (or ",;").
property theIgnoredPunctuation : "" -- Add punctuation to ignore it (or leave this property set to to an empty string "" to ignore all punctuation)
set theCharacterSet to script "DEVONthink - Ignore Punctuation"'s getCharacterSet(theIgnoredPunctuation)
set theTags to extract keywords from record thisRecord with existing tags
set theText to plain text of thisRecord
set theText_withoutPunctuation to script "DEVONthink - Ignore Punctuation"'s stripPunctuation(theText, theCharacterSet)
set theTag_Names to (name of tag groups of database of thisRecord) & (aliases of tag groups of database of thisRecord)
repeat with thisTag in theTag_Names
set thisTag to thisTag as string
if theText_withoutPunctuation contains thisTag then
set end of theTags to thisTag
if theTags ≠ {} then set tags of thisRecord to (tags of thisRecord) & theTags
return
end performSmartRule
Note:
Please test the script with duplicates in a new database. I don’t use tags or tag aliases that much so I might have missed something.
