I have the problem that items or groups often contain characters (for example, / % § & …). This causes errors when synchronizing (indexed) folders with my NAS. The NAS does not support such characters in file names.
Is it possible to develop a script / a smart rule, which automatically converts incompatible characters into another character (for example, “_”) when importing?
What kind of NAS do you use, which filesystem does it use and how is it mounted in the Finder (e.g. via SMB, AFP or WebDAV)? A simple test using a Synology DiskStation was successful, these characters are supported.
Might be a limitation of the sync software. However, a smart rule executing a script could handles this. But the script would have to change the titles of the items to update the filename, e.g. like this:
set od to AppleScript's text item delimiters
set theFixedName to my replaceText(theName, "§", "_")
set theFixedName to my replaceText(theFixedName, "/", "_")
set theFixedName to my replaceText(theFixedName, "%", "_")
set theFixedName to my replaceText(theFixedName, "&", "_")
if theFixedName is not equal to theName then set name of theRecord to theFixedName
end performSmartRule
on replaceText(t, s, r)
local temp_list
if t contains s then
set AppleScript's text item delimiters to s
set temp_list to text items of t
set AppleScript's text item delimiters to r
set t to temp_list as string
return t
end replaceText
I do not want to take your time too much, but is ist possible to shorten the name to e.g. 143 characters automatically? This seems to be a problem on Synology DS as well.
property pMaxLen : 143
if length of theFixedName > pMaxLen then set theFixedName to (characters 1 thru pMaxLen of theFixedName) as string
local temp_list
return t
end replaceText
And if you Devonthink heroes have some more time, it would be great if a smart rule could be triggered by (or after) renaming an item or a group. Maybe that’s easy to implement.
