Does anyone know of a script that I can use to convert one or more selected bookmarks in DT into a web-archive?
Have you tried from the Scripts menu:
Download->Create Offline Archive
That doesn’t work…
Any other thoughts?
This script supports all selected contents having a URL, not only bookmarks:
if theSelection is not {} then
activate
show progress indicator "Downloading..." steps (count of theSelection)
step progress indicator theName
if exists URL of theRecord then
set theURL to URL of theRecord
if theURL begins with "http:" or theURL begins with "https:" then
set theData to download web archive from theURL
if exists parent 1 of theRecord then
set theGroup to parent 1 of theRecord
else
set theGroup to missing value
set theArchive to create record with {name:theName, URL:theURL, type:html} in theGroup
set data of theArchive to theData
hide progress indicator
AWESOME!!
That works perfectly!! Thanks so much for your help…it’s much appreciated!
I have a large collection of bookmarks I would like to convert to web archives. When I use Christian’s script on a selection of bookmarks in DTPO 2 I get blank HTML documents named with the name of the original bookmark. The script Download > Create Offline Archive doesn’t appear to do anything (perhaps it puts its output somehwere not obvious?) Thanks.
I’m not an AppleScript expert, but maybe the following script works for you. I just modified the aforementioned script a little.
activate
else
create web document from theURL in theGroup name theName
Perfect. Works just as I would hope. Thanks!
[size=75](One caveat that has nothing to do with your work - if the bookmark points to a URL that is a PDF, then nothing is returned. As expected. However, there seems to be a bug (which might be due to the latest version of Adobe reader) that causes DTPO to crash when it is opening bookmarks pointing to PDFs. After 10 crashes in a row, I can confirm this is repeatable and has been submitted on a bug report to DT.)[/size]
For me the script returns a 0 byte html file, displaying a blank page. Wonder if it’s a Devonthink 2.0 issue, which I am using.
Actually the script requires v2.0 and is working fine over here. What’s the URL of the page you’re trying to convert?
This is a tremendously useful script, but I’m wondering what it would take to output markdown (with readability) instead of a web archive?
Just replace the “create web document from” command with “create Markdown from” and add the parameter “using Readability” if desired.
