Unfortunately, I have zero knowledge on both xml and json.
I tried to figure it out by myself for couple of days, but I could not find any solution.
When I try to search with keyword “samsung” from Anandtech website’s search engine,
I get the url below:
https://www.anandtech.com/SearchResults?q=samsung
In addition, if I click on the next page icon of the search results,
https://www.anandtech.com/SearchResults?CurrentPage=2&q=samsung&sort=date
I think I have to combine two urls in one plugin to get sufficient result on devonagent, but I have no clue how to combine them. (I tried to copy other plugins to use it as a scratchpad, but the provided urls were quite different, so I couldn’t successfully exploit this approach…)
When I use only one of the url form above in the devonagent’s plugin creator, I can only get partial results. (partial results means, around 20 final search results, while I get 34 page of results if I use website’s built in search engine.)
Please help me to find solution on this matter.
I would really like to build a ground knowledge from this case to work on other websites by myself.
There are two options:
Create a new search set, add the URL anandtech.com/show/ to the “Sites” tab and change the mode from “Crawl” to “Search”
Choose File > New Plugin, paste the following URL…
https://www.anandtech.com/SearchResults?CurrentPage=_agentOffset_&q=_agentQuery_&sort=date
…and then add this to the plugin’s code to get only the desired links:
<key>LinksMatching</key>
<string>*www.anandtech.com/show/*</string>
Thank you for your quick answer!
It helped me a lot to understand how it works.
However, I am wondering why my search using this plugin stops on page 4, every time.
I have modified my plugin to tackle this problem, but it didn’t work.
Now my plugin looks like this:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>Description</key>
<string>Searches the web using <www.anandtech.com>.</string>
<key>EngineUrl</key>
<string>https://www.anandtech.com/SearchResults?CurrentPage=_agentOffset_&q=_agentQuery_&sort=date</string>
<key>Identifier</key>
<string>www.anandtech.com</string>
<key>Info</key>
<string>Anandtech Plugin</string>
<key>Name</key>
<string>Anandtech</string>
<key>OffsetPerPage</key>
<integer>1</integer>
<key>Operators</key>
<integer>59</integer>
<key>ParseLinks</key>
<true/>
<key>ResultsPerPage</key>
<integer>15</integer>
<key>Start</key>
<key>Version</key>
<string>1.0</string>
</dict>
</plist>
Log pane from search result window says searching stops on page 4.
As I mentioned earlier, the result page should be 34 (and each page contains 15 result except for 34th page.)
I am wondering what am I missing…
By default only up to 100 results are used. You can customize this by creating a search set, enabling your plugin and changing the number of results per plugin.
