I have a database with several columns: Label, Location, Name, Spotlight Comment.
I generally keep it sorted by Label. When I do, the secondary sort is by Name. Is there a way I can change which column is the secondary sort?
DEVONthink doesn’t do secondary sorts. The workaround would be to sort the items in one way, then replicate them to a group and sort them differently.
