I’d like to set the selection to every PDF in DEVONthink’s inbox that needs to be OCR’ed. However, it seem that “set selection to list” command doesn’t work. The following script fails with an “AppleScript error -10000” as soon as there is at least one PDF without text:
set myWindow to open window for record incoming group
set myGroup to root of myWindow
set myList to every child of myGroup whose kind is "PDF"
set myWindow's selection to myList
I’d prefer to use “type” because of the reason you gave, however it seems that PDF containing text share the same type with “graphics-only” PDFs, so I resorted to use “kind” in order to find the PDFs without a text layer.
I just tried it again and there is an error logged to the console:
23.09.16 15:39:31,834 DEVONthink Pro[704]: -[DTRecord objectsByEvaluatingSpecifier]: unrecognized selector sent to instance 0x7fe01c85ef80
23.09.16 15:39:31,835 DEVONthink Pro[704]: An exception was thrown during execution of an NSScriptCommand...
23.09.16 15:39:31,835 DEVONthink Pro[704]: -[DTRecord objectsByEvaluatingSpecifier]: unrecognized selector sent to instance 0x7fe01c85ef80
This might be a bug of AppleScript or of DEVONthink Pro, I’ll check this. In the meantime just use a loop to retrieve the desired items:
set myChildren to children of myGroup
set myList to {}
repeat with theChild in myChildren
if kind of theChild is "PDF" then set myList to myList & theChild
Things are getting stranger and stranger. The code you posted doesn’t work here (OS X 10.11.6, DTPro 2.9.4) I got it to “work” by changing the if statement; however it still fails at the last statement (“set myWindow’s selection to myList”).
set myList to {}
if kind of theChild is "PDF" then set end of myList to theChild
set oWin to open window for record incoming group
set oRoot to root of (oWin)
set lstPDF to (children of oRoot where kind = "PDF") as list
return lstPDF
But I seem to get an error when I try to set the selection list of the window
Because I’d like to convert them to a searchable PDF with a single click (or a single call to “System Events”).
Unfortunately, the “Data → Convert → to searchable PDF” menu command isn’t exposed to AppleScript. I am aware of the “convert image” command. However, this creates a new record while the menu command converts the PDF “in place” which I prefer (especially because it ensures the UUID of the record stays the same, so that any references I created in OO4 or otherwhere will continue to work).
As a workaround I now open a new window for each PDF that needs to be converted and use System Events to do the OCR.
You can also automate in place OCR if you use an external application such as Abby Finereader or Smile’s PDFPenPro. Here is an example using Finereader [url]ABBYY Finereader Pro v12]
It would be more reliable than relying on system events.
