Should "document amount" return with or without $ and comma?
I’m trying to use “document amount” to pull the bill amount from email.
set theAmount to document amount of theRecord
Sometimes the string returned has a dollar sign and/or a comma, sometimes it doesn’t. For example, one email returned $1,187.00 (exactly as it was rendered in the email), while another returned 1352.00 although the email text was $1,352.00. These billing/payment emails uniformly include a dollar sign on the amount, with no intervening space.
The presence or absence of the comma makes no difference to me, but the inconsistency of the $ is making it difficult to use the result in constructing a new filename (do I concatenate with a “$” or not?) or coercing it to a number for later use (“set… as real” throws an error if the $ is there, but stripping the first character of the string removes a digit if the $ isn’t there).
How is “document amount” intended to work?
Is the format of the amount also identical after converting the emails to plain text (as only the text matters, not the visible layout)? Or could you send a zipped copy of these emails to cgrunenberg - at - devon-technologies.com? Then I could try to reproduce this over here, thanks.
Are the prices represented as links in the emails?
The format of the amounts are unchanged when converted to plain text. I have sent you a zip file of four emails.
No, just text.
