I wanted to ask if there’s any way to accomplish the following:
As a starting point, in the body of Markdown note A, an external link is added (e.g. application://xyz123ID). This link refers to Markdown note B indexed from the third-party application’s folder (non-DT link scheme).
Is there any way to show this relation in the links of Markdown note A and the incoming links of Markdown note B?
I was hoping that by adding the external URL referenced in Markdown note A to Markdown note B’s URL or aliases, this would happen automatically. But it doesn’t seem to be the case unless I’m overlooking something.
However, wouldn’t it make sense that items containing a link to the URL of another DevonThink item are also included in the Links inspector? I’d like to request this as a feature.
Yes, that’s also what I noticed: If a non-Devonthink URL is added, then it does show in the Links inspector.
Thinking this one step further, perhaps if the same external link has also been added as the URL of a second DevonThink database item B, then that database item could also show in the Links inspector of database item A.
This would also imply that database item A, from which the external link points to the URL of database item B, would show in item B’s incoming links.
