Hi,
Is it possible to have DTP import to the folder selected in the preferences (and only to the folder selected in the preferences) whether or not the method is a bookmarklet, drag and drop or script?
Organizing the database and having items import, via a script, to the root level is a bit of a PIA.
For example, the “Add Webarchive to DevonThink” script adds the selected page to the root level though I have my “Incoming” folder as the default for import.
thanks
