Slow navigation between groups
Hello,
it seems that navigating between groups is slower than it should be. Opening groups takes about 1 to 2 seconds. Going back is immediately. Is that on purpose?
Thanks!
There is not enough information to answer this.
  • Are they indexed groups?
    • If so, from where?
Thanks for your answer and the follow up question. Yes, please let me know what information is missing.
  • Files and grupos are imported, not indexed.
  • The connection is from the Mac via Bonjour to iPad (Pro 11" 1. Generation, latest stable release) and iPhone (11 Pro, latest stable release).
In DEVONthink, hold the Option key and choose Help > Report Bug.
The problem only appears on the iPhone and iPad. I’ve sent a Bug Report from the iPhone, referring to this topic. Hope it helps.
Thanks in advance.
