I have tagged a bunch of folders and documents OUT, meaning they’re the ones I’ve sent to my researcher to do some work on.
Then I created a Smart Group called “OUT”, but it seemed it want to search either Groups OR Documents, not both. I was finally able to create a Smart Group that found both Groups and Documents, but it seems a bit kludgy, so I wanted to ask you all if there’s an easier way.
Search in: Database
All of the following are true:
(Indent 1) Label is OUT
(Indent 1 Any of the following are true:
(Indent 2) Kind is Any Document
(Indent 2) All of the following are true:
(Indent 3) Kind is Group
This works, but for future reference is there an easier way?
