Smart Group for Recently Tagged Documents
DT’s excellent search feature almost always gives me what I need. But sometimes I don’t know exactly what I’m looking for.
I might remember that it’s a document I recently edited. Or maybe I just changed the name. Or perhaps I opened it recently without making any changes. For these cases, I use smart groups.
I’d also like to create a smart group that shows me documents that have been tagged recently, with any tag (within the last 10 days).
Is that possible? Thank you.
Tagging doesn’t mark a document as modified so there’s no temporal relationship with a tag. A mechanism to do that would have to be built by you and done in advance.
Do you have a specific suggestion? How would you do it?
You could use a smart rule and “On Tagging” fill a custom metadata field with the time of tagging.
This would allow you to set up smart rules to check on the tag and the time.
Not important, but this works too.
I am happy that it works for you, but the result is different.
Your solution lists all documents for a tag where the tag has been applied to only a subset of document(s) within the last 10 days. It lists documents which haven’t got a tag updated within that time period.
