--set theName to display name editor info "New Project:"
--if theName is not "" then
set theSmartGroup to create record with {name:"Kein Fälligkeitsdatum", type:smart group} in current group
set search predicates of theSmartGroup to "item:! Reminder"
set highlight occurrences of theSmartGroup to true
--end if
My Problem is, that I like to choose the "Search in: Area instead of database a current folder, how to mention this?
Why are you using a try… end try block here? While you’re developing the script, you’re inhibiting errors from being reported.
PS: Here’s a simple example…
set searchGroup to (display group selector)
set theSmartGroup to create record with ¬
{name:"Smart Group", type:smart group, search predicates:"kind:rtf", highlight occurrences:true, search group:searchGroup} in current group
