Smart rule based on keyword in name: how to apply only once
Hello,
I created the smart rule below to replicate items with “troubleshooting” in the name to 3 groups.
My problem is that every time I want to run the rule, I am asked if I want to apply it once again to all items with “troubleshooting” in the name.
Is there a way to indicate in the smart rule items with “troubleshooting” in the name which are already replicated to those 3 groups should be ignored.
thanks in advance for your time and help
Maybe you can add a custom field “replicated” and tick that field after replicating (in an action).
Then change your selection and add “not replicated”.
thank you. Very smart idea. You mean custom tag ?
You could use a flag, a label, a dedicated tag or custom metadata. Whatever you prefer and doesn’t disturb your current workflow.
thank you Christian
Sorry for the delayed answer: I meant a custom metadata field.
But as Christian suggested, you have several options.
