I created a rule to convert .eml files to html. I would like to then delete the original .eml, but my rule deletes the html file
thank you
thank you
After a Convert & Continue action the next actions are applied to the converted file, in case of a Convert action to the original file. Therefore Add Tags, Convert and Move To Trash in that order should do it.
great. thank you
