Hi All,
I found this to happen as I am setting up smart rules in DT3:
I have so far 5 DBs because I need separate classifications to happen.
I have to duplicate rules multiple times to make them work on multiple DBs because there is always that coupe DBs where the rule does not apply. is there a way to run a rule on multiple but not all databases?
also, is there a way, alternatively or in parallel, to create visual folders for smart rules? now they are all just there in a bunch, I can just reorder them.
What is the best method for setting up multiple “Search in” locations for a Smart Rule?
I have a Smart Rule whose criteria I want to apply to several locations across my database. (The rule will replicate a group’s contents to a particular “quick links” group.)
Do I need to create a separate Smart Rule, with the same criteria, for every group location to which I want to apply the rule?
[Sorry. I didn’t intend to “reply” to a particular person. I couldn’t figure out how to change that once I’d done it.]
If I understand you correctly, this would seem to negate the reason for the particular Smart Rule. If I (manually) replicate them, then there would seem to be no need to replicate them using the Smart Rule.
Here the two groups have been replicated to one group - Search here. Now you can target that group and effectively search only those two groups in one smart rule.
