[SOLVED] Databases not automatically opened after dt3 upgrade
The old dt2 used to automatically open the last used db’s but after upgrading to version 3 I have to occasionally reopen them from “recents”.
Reading this forum I am not sure if the behavior has changed or not. I have been unable to find any setting for it either.
DT3 will reopen databases which were open when the program itself was last closed. It will not automatically open any databases which were closed at the point in time the program was ended. I‘m not aware of any setting which would allow you to modify that behaviour.
Ok, so keeping db’s open is the default behavior.
I then must have been encountering some bug because I never intentionally close them yet sometimes I find them closed.
Did you quit the app via the Dock menu? In this case there’s indeed a bug that will be fixed by the next maintenance release.
I am not sure. It might happen when I boot the computer so it is probably because of that bug then.
