DEVONthink 4 has its own Application Support folder “~/Application Support/DEVONthink” containing the new Inbox.
I have a large number of Hazel rules sending files to the DT3 Inbox which is located in the “DEVONthink 3” Application Support folder.
Other than editing each rule, is there an easier way to update these or modify the behavior? I suppose I could create another rule to move any files from the old Finder Inbox to the new one but that’s a bit of a kludge.
Has anyone found another solution?
EDIT: I didn’t search enough, Hazel has a way to do this! but note:
Relocate folder now broken out into its own window accessible from the Folders->Replace Folder… menu
Sorry for any inconveniece, hopefully this will help someone else.
