DTP 4.4 OSX 26.7
Edits made in iA Writer are not reflected in DEVONthink
Steps: 1. Open a Markdown record in iA Writer from DEVONthink.
2. Edit and save in iA Writer. Closing iA Writer asks to save; saved.
3. Return to DEVONthink and select the record.
Result: DEVONthink keeps showing the old content. Reopening the file in iA Writer shows the edits and the correct path inside the database package, so the file on disk is updated. Selecting another record and going back does not refresh it. Reopening the database does not refresh it either.
Workaround found: in DEVONthink, choose Show in Finder, then open the same file from Finder with iA Writer. At that moment DEVONthink updates and shows the edited content. Expected: DEVONthink detects saves made to the file by the external editor, as it did previously with the same workflow.
Question: is this a known issue, and is there a setting or command that forces DEVONthink to re-read a changed file inside the database?
SOLVED: Updated IA Writer. Text is updated correctly.
