Solved - Need help - DTTG and MacOS 27 - no Search results
Just got my iPad Air M4, installed DTTG, sync’d my databases beautifully fast, but I do have an issue: searching for anything (e.g, “Passport”) does not result in anything. No search results, nothing. Have I failed to do something after installing and syncing?
Importing isn’t the end of the process. It needs to index things as well. Have you given it time to finish this?
thanks Jim - I did, then I remembered something else you said a while ago and restarted the iPad, and there it was.
So it had been indexed, but needed restarting.
You’re welcome and I’m glad to hear all is well again!
