I often find it tiresome using DT Pro’s contextual menus to move, replicate etc, and drag and drop can be a pain, especially on a notebook. So I’ve whipped together a number of little scripts that, when assigned hotkeys (for example, using Red Sweater Software’s wonderful FastScripts program) makes it possible to zip about DT with a couple of keystrokes. They’re all dead simple, but perhaps people with more scripting know-how than my cruelly limited skills can do more with them.
The first moves the selected records to a location chosen via the standard pop-up list:
--MOVE TO...
set theRecords to the selection
set inGroup to display group selector "Move to:" buttons {"Cancel", "OK"}
move record thisRecord to inGroup
The second allows you to replicate records in the same way:
--REPLICATE TO...
set inGroup to display group selector "Replicate to:" buttons {"Cancel", "OK"}
replicate record thisRecord to inGroup
The third takes you to the desired location ie opens its window. Not much of an advance on double-clicking in the Show Groups list, but might come in handy for some uses:
-- GO TO...
set inGroup to display group selector "Go to:" buttons {"Cancel", "OK"}
open window for record inGroup
The fourth creates a new text note in the desired location, and opens the window, ready for you to type in. Put this in the general scripts folder, assign a hot-key, and you have system-wide, quick-access way to enter notes in DT:
--QUICK TEXT NOTE:
activate
set inGroup to display group selector "Make new note in:" buttons {"Cancel", "OK"}
display dialog "Title of note:" default answer "" buttons {"Cancel", "OK"} default button 2
set theTitle to the text returned of the result
set theNote to create record with {name:theTitle, type:txt} in inGroup
open window for record theNote
The fifth opens a browser window to whatever URL you enter (and saves the address for good measure):
--GO TO URL:
activate
set inGroup to display group selector "Make link in:" buttons {"Cancel", "OK"}
display dialog "Go to URL:" default answer "" buttons {"Cancel", "OK"} default button 2
set theURL to "http://" & the text returned of the result
set theLink to create record with {name:"New Link", type:link, URL:theURL} in inGroup
open window for record theLink
The sixth “bookmarks” the URL of whatever page you are viewing in the location indicated:
--SAVE URL
activate
set inGroup to display group selector "Bookmark URL in:" buttons {"Cancel", "OK"}
set theURL to URL of front window
set theTitle to name of front window
set theLink to create record with {name:theTitle, type:link, URL:theURL} in inGroup
I’ve used the pop-up folder list in each of these, but of course you could set a fixed location to move, replicate etc into as follows:
set inGroup to create location "/IN BOX"
[i]File your documents with one keypress! Jump straight to your most-used folders!
Finally, a couple of extras. This one saves the currently open tabs in NetNewsWire in html form:[/i]
--SAVE NETNEWSWIRE TABS
tell application "NetNewsWire"
set titleList to titles of tabs
set urlList to URLs of tabs
set tabComp to ""
repeat with i from 2 to the count of titleList
set tabData to "<a href='" & item i of urlList & "' target='_blank'>" & item i of titleList & "</a>
" & "[" & item i of urlList & "]" & "
set tabComp to tabComp & tabData
create record with {name:"NetNewsWire Tabs", type:html, source:tabComp} in inGroup
And this one hacks together the standard-issue DT script for importing messages from Mail and Red Sweater’s Save HTML Content script. Presto: a script that imports html messages:
--IMPORT HTML MESSAGES FROM MAIL
property pNoSubjectString : "(no subject)"
property pLocation : "/IN BOX"
tell application "Mail"
if not (exists current database) then error "No database is in use."
set theLocation to create location pLocation
if the length of theSelection is less than 1 then error "One or more messages must be selected."
repeat with theMessage in theSelection
my importMessage(theMessage, theLocation)
«event sysodisA» "Mail" given «class mesS»:error_message, «class as A»:«constant EAlTwarN»
on error number error_number
if error_number is -1708 then display dialog error_message buttons {"OK"} default button 1
on importMessage(theMessage, theLocation)
set theDateReceived to the date received of theMessage
set theDateSent to the date sent of theMessage
set theSender to the sender of theMessage
set theSubject to subject of theMessage
if theSubject is equal to "" then set theSubject to pNoSubjectString
set theContent to the source of theMessage
set theHTMLContent to my TextBetweenTwoTags(theContent, "<html", "</html>")
tell application "DEVONthink Pro" to create record with {name:theSubject, type:html, creation date:theDateSent, modification date:theDateReceived, URL:theSender, plain text:(theHTMLContent as string)} in theLocation
set the flagged status of theMessage to true
end importMessage
on TextBetweenTwoTags(theText, startTag, endTag)
set foundText to ""
set startOffset to offset of startTag in theText
set endOffset to offset of endTag in theText
if endOffset is equal to 0 then
set endOffset to length of theText
else
set endOffset to endOffset + (length of endTag)
-- If we got a reasonable looking subset...
if (startOffset is greater than 0 and endOffset is greater than startOffset) then
set foundText to (texts startOffset through endOffset of theText)
return foundText
end TextBetweenTwoTags
