When I do a search, the results are by default sorted by ‘score’. I find this very helpful as the most relevant results are near the top. But if I save the search as a smart group, the results are sorted by title. Is there a way to have smart group results sorted by score?
Thanks
Doubtful, since Score isn’t available under View > Sort or View > Columns.
That’s what I thought too.
Consider it a feature request then.
Thanks.
SJK is correct, as “Score” isn’t an available column choice.
But if it’s important to see a score sort for a particular smart group, that can be done by performing a new search using the same criteria as the smart group.
Another of my infamous kludges.
