When using the Sorter, if the input method is set to Chinese, it automatically switches from the “Name” field to the “Body” field while typing. The specific behavior can be seen in the video file linked.
https://i.see.you/2026/03/31/R2dw/20260331173646999.mp4
Version details: DEVONthink 4 Version 4.2.2, macOS 26.4 (25E246), Chinese input method: RIME.
RIME isn’t a built-in input method so there is no specific support for it. With a macOS-provided model, I’m seeing no misbehavior…
Thank you for your reply!
You’re welcome!
I just tried testing it using the built-in input method on macOS, and the same bug still occurs. Please see the video file.
