Using 2.0.3, when I split a document, the screen becomes unresponsive. Clicking anywhere in DevonThink has no effect whatsoever. I cannot select databases, or document groups. Any click on the application screen does nothing. I can selelct menu items, but they have no effect. So if I choose View > As Icons, nothing happens.
I have to quite the application, which I can do successfully from the menu. Then as soon as I split another document, it happens again. This is causing me considerable problems with my work.
Is it just my machine/installation? And can anyone suggest how I fix it?
This is a fairly major bug, and I would have thought would warrant a fix without having to wait for a scheduled release.
is there a target date for 2.0.4? This really is causing me major problems with how we work, and the Copy/New work around add very many extra clicks to our workflow.
Split document is working over here on 2.0.4. How large are the documents you are spliting? Have you sent a sample document (one that fails) to DTech support for testing?
