可以给 “split document"设置一个快捷键吗?
拆分长文本时,需要右键,然后再点击“split document",最终才能拆分。这些步骤实在太麻烦了。如果有个快捷键就好太多了,谢谢!
DeepL translation for convenience:
When splitting long text, you need to right-click and then click on “split document” to finally split it. These steps are too cumbersome. A shortcut would be great, thanks!
Stephen
Thanks!
You could add a shortcut to Tools > Split Document via system preferences.
@DEVONthinker123
Further to @cgruenberg, as I was curious about this feature of MacOS, I setup a shortcut per Create keyboard shortcuts for apps on Mac – Apple Support (UK) found via Google as per screen shot. Spitting documents not something to do very often, but learning again how to do my own short-cuts for app menu commands was learning (perhaps re-learning) of the week.
So many things we can do for ourselves to meet individual needs! :wink:
thinks!
