Stamps & Smart Rules Issue
Hi There,
I have an issue when stamping a pdf with a smart rule and syncing this to another device.
This is my workflow:
  • General Inbox: Upload PDF File
  • Label the PDF File with a color code
  • After next sync, the smart rule grabs the PDF file, removes the label and stamps it
  • After next sync, I can sync the pdf file to my iPad
  • on my iPad, I can see a preview of the file with the stamp on it
  • when I download the file, the stamp is not visible on the document
What I discovered so far:
  • This seems only to happen when stamping with a smart rule
  • Setting the stamp manually (with the same process - Label, wait for Sync, Stamp, etc), I was not able to see this behavior
  • I can remove the file from the iPad (Remove Locally), sync it again, the stamp is still not there
Any ideas? Is this maybe a bug?
Thank you for your answers.
Volker
A screenshot of the smart rule would be useful, thanks.
Here is the screenshot. However it is the other way round. It removes the label and then do the stamp.
I will update the description above.
Volker
And her two screenshots for the stamp configuration.
That’s a known issue of the current version, the next release will fix this.
