Sorry but there currently is no option for styling a clutter-free capture or assigning user-defined styling in DEVONthink To Go.
Unless you do some fancy Shortcuts work and use DT3 as a conversion back-end:
Hi,
Would you mind to share again the link to your stylesheeet? The actual one is broken. Thanks a lot.
Hi @Claude,
I will embed the code, just save the following as a CSS file and you should be good to go!
/* Pretentious
* Brett Terpstra
article, aside, details, figcaption, figure, footer, header, hgroup, nav, section, summary {
display: block
audio, canvas, video {
display: inline-block;
*display: inline;
*zoom: 1;
audio:not([controls]) {
display: none;
height: 0
[hidden] {
display: none
html {
font-size: 100%;
-webkit-text-size-adjust: 100%;
-ms-text-size-adjust: 100%
html, button, input, select, textarea {
font-family: sans-serif
body {
margin: 0
a:focus {
outline: thin dotted
a:hover, a:active {
outline: 0
h1 {
font-size: 2em;
margin: .67em 0
h2 {
font-size: 1.5em;
margin: .83em 0
h3 {
font-size: 1.17em;
margin: 1em 0
h4 {
font-size: 1em;
margin: 1.33em 0
h5 {
font-size: .83em;
margin: 1.67em 0
h6 {
font-size: .75em;
margin: 2.33em 0
abbr[title] {
border-bottom: 1px dotted
b, strong {
font-weight: bold
blockquote {
margin: 1em 40px
dfn {
font-style: italic
mark {
background: #ff0;
color: #000
p, pre {
margin: 1em 0
pre, code, kbd, samp {
font-family: 'courier new', monospace;
font-size: 1em;
white-space: pre-wrap;
pre {
padding: .5rem 2rem;
font-size: .95rem;
background: rgba(255, 255, 255, .75);
border-radius: 10px;
white-space: pre;
word-wrap: break-word
q {
quotes: none
q:before, q:after {
content: '';
content: none
small {
font-size: 75%
sub, sup {
font-size: 75%;
line-height: 0;
position: relative;
vertical-align: baseline
sup {
top: -0.5em
sub {
bottom: -0.25em
dl, menu, ol, ul {
margin: 1em 0
dt {
font-weight: 600;
dd {
margin: 0 0 0 40px
menu, ol, ul {
padding: 0 0 0 40px
nav ul, nav ol {
list-style: none;
list-style-image: none
li p:first-child {
margin: 0;
img {
border: 0;
-ms-interpolation-mode: bicubic;
max-width: 100%;
height: auto;
svg:not(:root) {
overflow: hidden
figure {
margin: 0
form {
margin: 0
fieldset {
border: 1px solid #c0c0c0;
margin: 0 2px;
padding: .35em .625em .75em
legend {
border: 0;
padding: 0;
white-space: normal;
*margin-left: -7px
font-size: 100%;
margin: 0;
vertical-align: baseline;
*vertical-align: middle
button, input {
line-height: normal
button, input[type='button'], input[type='reset'], input[type='submit'] {
cursor: pointer;
-webkit-appearance: button;
*overflow: visible
button[disabled], input[disabled] {
cursor: default
input[type='checkbox'], input[type='radio'] {
box-sizing: border-box;
padding: 0;
*height: 13px;
*width: 13px
input[type='search'] {
-webkit-appearance: textfield;
-moz-box-sizing: content-box;
-webkit-box-sizing: content-box;
input[type='search']::-webkit-search-decoration, input[type='search']::-webkit-search-cancel-button {
-webkit-appearance: none
button::-moz-focus-inner, input::-moz-focus-inner {
border: 0;
padding: 0
textarea {
overflow: auto;
vertical-align: top
table {
border-collapse: collapse;
border-spacing: 0
body {
background: #faf9f5;
color: #333;
font-family: "Helvetica Neue", Arial, Helvetica, sans-serif;
font-size: 16px;
line-height: 170%;
text-align: left;
padding: 20px
table {
margin-bottom: 2em;
padding: 0;
font-size: 14px;
min-width: 70%;
margin: 0 0 2em 2rem;
border: 1px solid #ddd;
border-collapse: separate;
*border-collapse: collapse;
-webkit-border-radius: 4px;
-moz-border-radius: 4px;
border-radius: 4px
table caption, table col, table colgroup, table table, table tbody, table td, table tfoot, table th, table thead, table tr {
border-spacing: 0;
font-family: Helvetica, Arial, sans-serif;
font-weight: 400;
font-size: 24px
table caption {
display: table-caption;
font-weight: 700;
font-size: 12px;
text-transform: uppercase;
font-family: Helvetica;
background: rgb(135, 134, 130);
color: #EEE;
padding: 8px 4px;
border-radius: 4px;
margin: 4px 0;
table col {
display: table-column
table colgroup {
display: table-column-group
table tbody {
display: table-row-group
table tfoot {
display: table-footer-group
table th, table td {
padding: 10px 10px 9px;
line-height: 18px;
text-align: left
table th {
padding-top: 9px;
font-size: 14px;
font-weight: 700 !important;
vertical-align: middle;
text-align: center;
table td {
vertical-align: top;
border-top: 1px solid #ddd;
font-family: Helvetica serif;
font-size: 14px !important
table tbody th {
vertical-align: top
table th+th, table td+td, table th+td {
border-left: 1px solid #ddd
table thead tr:first-child th:first-child, table tbody tr:first-child td:first-child {
-webkit-border-radius: 4px 0 0 0;
-moz-border-radius: 4px 0 0 0;
table thead tr:first-child th:last-child {
-webkit-border-radius: 0 4px 0 0;
-moz-border-radius: 0 4px 0 0;
table tr:nth-child(odd), table th:nth-child(odd), table td:nth-child(odd) {
background: rgba(255, 255, 255, 0.06)
table tr:nth-child(even), table td:nth-child(even) {
background: rgba(0, 0, 0, 0.06)
table tbody tr:first-child td:last-child {
table tbody tr:last-child td:first-child {
-webkit-border-radius: 0 0 0 4px;
-moz-border-radius: 0 0 0 4px;
table tbody tr:last-child td:last-child {
-webkit-border-radius: 0 0 4px 0;
-moz-border-radius: 0 0 4px 0;
table tbody tr:nth-child(odd) {
background-color: rgba(0, 0, 0, 0.03)
figure {
position: relative;
margin: 1em auto 2em 2rem;
width: auto;
figcaption {
font-style: italic;
text-align: center;
background: white;
color: #444;
position: absolute;
left: 0;
bottom: -24px;
width: 98%;
padding: 1%;
-webkit-transition: all .2s ease-in-out;
-moz-transition: all .2s ease-in-out;
-o-transition: all .2s ease-in-out;
-ms-transition: all .2s ease-in-out;
ul {
list-style: circle
ul ul, ol ol, ul ol, ol ul {
margin: 0;
a:link, a:visited {
text-decoration: none;
border-bottom: 1px solid;
color: rgba(31, 159, 194, 1)
a:hover, a:active {
color: rgba(91, 219, 255, 1)
CriticMarkup CSS by Fletcher T. Penney
Shows CSS tricks to improve visibility of CriticMarkup output
del {
background: #fae6e6;
ins {
background: #ecfce6;
span.critic.comment {
color: #0000bb;
span.critic.comment::before {
content: "{>> ";
span.critic.comment::after {
content: " <<}";
Thanks,
Adam
Thanks a lot Adam, that’s really nice of you!
