I’ve used two Smart Rules that process records (added via DTTG) from the global inbox (renamed it to “Admin”) for quite some time and they (almost) always worked.
Now it seems only the first one is triggered. Not sure when this started but I think it was after 3.8.
I first suspected it could be a problem with the Smart Rule that uses an AppleScript (although this should still be fine), so I tested the Smart Rules in reverse order. After that I added a third one that simply should add a label.
No matter what order I tried, there’s always only the first Rule triggered. Restarted DEVONthink , but it didn’t make a difference.
