With a new laptop I followed the video tutorial on syncing an happily synced between desktop iMac and the laptop, using Dropbox, adding various articles to the inbox of a new database on both machines.
However, yesterday I started adding folders on the laptop so I could sort the saved articles (pdfs) into various categories which hadn’t been obvious to come up with when I began the work.
Both last night and tonight, after closing down the laptop, the sync has failed to work on the iMac at home. None of the folders appear and the sync ends with the error message: “20:53:41: Sync: Europe → Simons-MacBook-Air.local. (Direct Connection) Could not open the connection (the specified host could not be found.”
How has creating folders on the laptop suddenly created a syncing problem? If I bring the laptop back, how do I find all the right files to copy the DT database and all it needs to my iMac in the hope it will then sync correctly in future (if that is sensible?)
Perhaps I’ve set it up wrongly, misunderstanding the original tutorial.
I’d like to work on a laptop while in the office, close it down, and then be able to work from the same database, updated, on my desktop machine later and vice versa.
