Instead of darker grey on light grey, I suggest that results appear yellow highlight.
thank you
Which version of macOS do you use? Did you enable any accessibility options in system preferences?
Catalina 10.15.7 latest update
Accessibility: no, I have not
thank you Christian
A screenshot would be useful too, thanks.
The name of the groups is actually black as expected, only empty groups use dark grey to easily recognize them.
There is a misunderstanding. My fault for not expressing myself clearly.
I was referring to the highlight background color of the go to group
Thank you, we might change this in the future depending on feedback.
thank you Christian
