I would like to be able to use the ‘Services/Summarize’ feature of OS X to summarize long articles stored in DTP. I would like to do so, by using Automator to look for the group, or by selecting articles from a search. My challenge is - I do not find a “summarize” action in DTP actions for Automator, or in any of the Apple Applications, ‘Finder,’ or 'System actions.
My objective is to summarize articles; convert the text to audio and then save the audio files to iTunes and have iTunes automatically transfer the files to my iPod. [Apples ‘Summarize’ feature is very cool (and accurate) and using Cepstral voices, it is very understandable as an audio file!]
I am a novice with Automator but have successfully created an Automator workflow that finds a group in DTP, reads a [full] article and converts the text to speech and saves it to iTunes. I just can’t create the ‘summary’ of the article before the text to speech conversion.
If I knew Apple Script, I’d be happy to try. Alas, I do not.
Your workflow sounds neat (pun intended).
For example, an apple script might capture text to the clipboard, launch summary services from the services menu and then hand off the result to your workflow.
Alternatively, an applescript could capture the text, launch summary services and create a new file in a specific DTP group, which could be acted upon by your workflow.
Thanks to both who replied. Sadly, I do not know how to use scripts. Can the script be used directly in Automator? Or does it need to somehow be converted, for use in Automator.
