Is there anyone out there that can work me through sync-ing two users in one common Dropbox, on two different computers? I’ve read the posts about the risks, etc… and I understand, but between myself and my partner we have a need to access/search the same documents offline and while apart.
I’ve read the earlier posts and they don’t make too much sense to me in how they work. If Dropbox isn’t the way to do it, another common server would be fine as well.
Okay I’m trying to accomplish this now, but I don’t know how to make a WebDav, I signed up for Azure, but not sure. Is there a step by step guide for this?
You would set up the Dropbox sync with the common credentials in DEVONthink on your machine and sync the database.
Then your colleague would set up the Dropnbox sync with the same credentials in DEVONthink on their machine and import the database from the Remote section in the sync location.
Now changes made by either of you would propagate to the other.
It still isn’t working, do you have an instant messaging where I could go through this step by step? I don’t see anywhere to log into Dropbox itself, am I missing something in Bonjour?
From the info and screen shots provided, it’s really hard to tell what is going on and how you are setup.
As a first step, I recommend you go through the “Troubleshooting” Chapter, section on sync in the DEVONthink Manual, starting on page 186 of the Version 3.8.6 of the document (PDF).
As a second step, re-read and check if you indeed exactly followed the instructions for setting up a Dropbox sync, page 66 of the that same document.
Perhaps consider starting again? To do so, you can “Clean location…” the Dropbox set-up to remove the sync files on the Dropbox server. You will see that when you read the Trouble shooting chapter.
Last question: Does your Dropbox have enough space to hold the DEVONthink sync files? Paid or “free” account with Dropbox?
One of your store is “milesdropbox” and the other is “MilesDropBox”, both must be same name including upper and lower case. Or milesdropbox or MilesDropBox. Delete “milesdropbox” sync database at your partner’s and create a new one called “MilesDropBox”.
In relation to WebDAV, you should have a WebDAV capable serve. I don’t know if Azure has WebDAV interface, my Sinology has (if you enable and configure it).
Does your colleague already have copies of the database on their machine?
If so, they would be in the Local section of the sync location - after creating the properly named location as noted previously. This would merge with the sync data in the Dropbox sync location instead of having to import the database.
Thus far, nothing has worked. Is there anyone like Live Support that I can call in to and see if this can be fixed? All these replies have been very helpful, but I cannot get it to work at all on my end. I do appreciate the feed back
