I have copied the database to an new computer in order to replace the other one. Syncing does not work for the huge database. It make running out of memory the two computers, i guess with memory leaks (i thought this was solved ?!).
The computer that has 30 GB free space (the 40 GB database is already there!), runs out of memory after hours of sync.
I may be hijacking the post, but with your very large database, how do you handle opening and using it? I have a supidly large database (around 12Gb of archived email), and it takes literally about 10-12 min to load, and is incredibly slow doing anything in it. Curious if you turned off classification, or anything else, to help improve speed. Part of me wants access to it so I can move stuff I actually need out of it, then torch the database because of the problems in it. I have been getting in the habit of using AppleScript to just clip the email if I decide it’s important enough to keep around for a long period.
