Trying to sync from DTPO to DTTG using bonjour.
I am able to set up the iPad as the server, and the imac to recognize it - so any databases already on the iPad can be synced with the imac
However, I can’t set up the iMac as the server - the iPad does not seem to see the iMac in the locations menu. Clearly the two computers do see each other on the network - so what can be the problem?
How are you determining this if the Mac isn’t seen as a Sync location on the iPad?
In Bonjour On in DEVONthink on the Mac?
In response to
- In the locations setting on the ipad, it lists all the locations it sees - and they are a) New box account b) New CloudMe account c) New dropbox account d) New webdav server
Nothing else
In the locatin setting on the Mac, it sees the ipad
Yes.
Have you quit and relaunched both apps?
restarted devonthink as suggested - problem solved1 thanks
