Fonts print very small when printing a table. It appears this is caused by an invisible row above the table that the ruler shows to be about 15 inches wide while the table itself is 7 inches wide. I’m thinking the existence of the invisible row is the cause of my problem…the shrinking of print output to accommodate its length.
I have attempted to delete or resize the row in question with no success. I’m open to suggestions for a fix…thanks.
It’s the 15" wide invisible rows that are causing the body of the table to print very small. This appears to be because the print driver it attempting to scale output to include the wide rows.
Move the right margin to your desired location.
The page size is determined by what paper size you’re printing to in File > Page Setup. You should also be able to set up page margins for the paper size too.
By right margin, do you mean adjusting the width of the application window? I’m not seeing another obvious method.
Here’s a shot of the Page Setup dialog. I can select everything except margins. There’s also no option for margins in the Print dialog. Is the option available elsewhere?
I do notice the position of the right window edge in TextEdit has no bearing on the print margin as it does in DEVONthink. I pasted my table into a TextEdit window to see whether it’s function would be the same.
I find DEVONthink’s implementation a bit odd, but now that I know how it works it’ll be fine. I don’t expect to be printing tables often.
