Textexpander can be useful if you frequently tag documents with the same set of tags. Say “DT”, “tips”, “forum” is the tag set. For example, create a Textexpander snippet “DT%key:tab%tips%key:tab%forum%key:tab%” and assign it to a key combination - say, “/tip”. Use that “/tip” key combo in the tags bar and it expands into the three separate tags.
thanks for the tip! I’ve moved it to the “Tips & Tricks” board.
