I want to sort records’ tags so that I can efficiently scan them.
I set up a test database that has Exclude groups from tagging enabled. It has three groups, A, B, and C. These Groups have their Group name specified in the Tags section as Tag to be applied in their Info dialog.
I have a record in Group C that is tagged with the tags: C, X, V, E, and A, applied in this order.
C is a tag that resulted from the record residing in a Group named “C.” This Group has the Tag “C” specified in its Info dialog.
Of the other tags, A is another Group tag, and the rest are “ordinary” tags, not associated with any Group.
The code below runs without error.
-- get the record's tags, sort them, and reapply the sorted list of tags.
set theRecs to selection
repeat with rec in theRecs
set theTags to tags of rec
my showTags(theTags)
set theTags to my simpleSort(theTags)
set tags of rec to {}
set tags of rec to theTags
on error errmsg number errnum
if the errnum is not -128 then display alert "DEVONthink Pro" message errmsg as warning
on showTags(tagList)
set str to ""
repeat with t in tagList
set str to str & t & " "
display dialog str
end showTags
-- thanks to http://www.macosxautomation.com/applescript/sbrt/sbrt-05.html
-- (modified for clarity)
on simpleSort(theList)
set the indexList to {}
set the sortedList to {}
repeat (the number of items in theList) times
set the lowItem to ""
repeat with ctr from 1 to (number of items in theList)
if ctr is not in the indexList then
set thisItem to item ctr of theList as text
if the lowItem is "" then
set the lowItem to thisItem
set the lowItemIndex to ctr
else if thisItem comes before the lowItem then
set the end of sortedList to the lowItem
set the end of the indexList to the lowItemIndex
return the sortedList
end simpleSort
The Events and Replies in the AppleScript editor shows:
get selection
--> {content id 116 of database id 14}
get tags of content id 116 of database id 14
--> {"C", "X", "V", "E", "A"}
tell application "AppleScript Editor"
display dialog "C X V E A "
--> {button returned:"OK"}
display dialog "A C E V X "
set tags of content id 116 of database id 14 to {}
set tags of content id 116 of database id 14 to {"A", "C", "E", "V", "X"}
--> {"C", "A", "E", "V", "X"}
display dialog "C A E V X "
Result:
All indications are that the list of tags has been sorted and passed to DTPO. I would expect that after deleting the record’s tags, that the new list of tags would be applied in the order specified. But, the sorted list of A, C, E, V, X is not applied. Instead, this list is applied: C, A, E, V, X.
It appears that the Group Tag of the Group in which the record was created is applied first, despite the sorted order of the tags.
Moreover, this code works as expected if Enable groups from tagging is not selected in the database properties. That is, the sorted list is actually applied.
This seems like a bug to me in DTPO’s application of Tags to records.
Any thoughts? Thanks.
