Tags not removed correctly in the index
I noticed a problem with the workflow I described there.
The shortcut uses the action to search for items for each of the state tags (e.g. search for “tags:#todo”). Somehow the database (meta information!?) got corrupted, because if I did the same search in the app, I got different results like I see in the created overview item. I solved it by doing a “reindex” on iOS
Thanks for the info.
