Hello,
I am a developer and lately I am evaluating technologies to build a desktop-like web app.
As I am taking a look to the Cappuccino framework, I read it is used for building the Web Interface of DEVONthink Pro.
However in some of your blog posts I read you completely re-written that interface.
As I say Cappuccino not really updated in the last years, I am wondering if you move from that stack and if you build your own UI framework (it’s beautiful) or you are leveraging some existing one.
Thank you
Welcome @tcaland
Thanks for your nice feedback.
@aedwards ?
@tcaland We stopped using Cappuccino as development on that framework slowed down then stopped completely some years ago. We now use Vue.js with the Quasar framework (https://quasar.dev).
thank you @aedwards for the answer.
I see that Quasar use a Material Design widget set, while I love your Cocoa like ones. Where I can find them or did you developed internally?
thanks
Earlier versions of Quasar had an iOS theme, however since v1 this has changed and you now use either the $q.platform.is.ios hook to style the components, and/or generate your own theme with the theme builder.
