Things 3 Quick Entry doesnt work with DT4 - anyone else have this problem?
Using Things 3 Quick Entry is very, very important in my daily workflow.
Things 3 and DT3 were working without problem, meaning with Quick Entry from T3 I was grabbing the name and link of the selected DT3 item.
Now I realized it doesnt work it DT4.
On below dialog I clicked “Allow”
Also this is the status in Mac Settings:
Is anyone use Things 3 + DT4 and do you have same problem ?
Of course having solution would be great.
I am aware of below, but that is too slow solution for me:
Thanks all
DEVONthink 4 has been released few days ago, it’s possible that Things 3 needs an update.
Why would you think this is an issue with DEVONthink?
PS: I know for certain CulturedCode is aware of the issue and working on a fix. As to when it’s released, that’s a question for them.
Thanks Christian / Jim and my apologies if my post suggested I’m pointing fingers.
It was about to check if others have similar problem so I know it’s not about my setup.
The reason to think that it’s problem with my DT4 was one post in this forum from past where user had similar problem and solved it with reinstall of both, DT and T3 ( which I hope wont be the case ).
But I think makes sense to wait for CultureCode and new update.
As always thanks for prompt follow up
Cheers
No offense taken or detected at all. I was just curious about your thought process since the issue was with Things’ quick entry, not DEVONthink.
This is certainly not something you should be considering early in troubleshooting. See…
… I like the example with the car not working :grinning_face:
Looks like it’s fixed in the new test builds
The public release, update 3.21.13 is now on the Mac AppStore, etc. as of today.
aaaand it’s working .. the QuickEntry :slight_smile:
Thanks all
