In one of my databases in DTPro, the 3 pane view shows no file listing data (just column headings) in the right hand pane. To see the data, I have to double click a folder icon in the Left hand pane.
Other databases are ok
Any ideas how to fix this?
Thanks Gareth
A screenshot of both list view and three-pane view would be useful, thanks.
Problem fixed!
Somehow, the divider in the middle of the right hand pane, had been moved as far up as possible, which then hid the file listing.
By moving the mouse around the column headers, the pointer changes and I was able to drag down the centre bar which revealed the file listing…
