Cumbersome little newbie problem:
What to do when the tags of a record do not fit within the tag bar at the bottom of the window? OK, I can click the tag bar and navigate with the left and right arrow keys. But is there no way to see all the tags of a record at a glance, regardless of how many and how long they are?
Only the Tags bar and the Info panel display all tags right now and space is indeed limited. But this is a known issue and will be improved by an upcoming release.
I’m curious if this was fixed, as I have the same problem. Is there a way to limit the tags to just those where the item is actually filed (i.e. not including the full path for groups that are acting as tags)? Or ideally - a convenient way to toggle between the two views?
Thanks in advance.
