Hi all,
I found two weird DT-related behavious in my Mac, which I attribute to the use of CleanMyMac, but perhaps is something else.
I’ve been using CleanMyMac for a couple months now. I use normally the Cleanup option, which deletes System Junk, such as User Cache Files, System Cache Files, System Log Files, User Log Files and Language Files. Normally it says it cleans about 2gb of Junk.
A couple of days ago, I used something else. I am not sure what it was, but I think it was the Extensions section. I don’t remeber but I might have ‘cleaned’ something there.
Since that day, the Clip to devonthink extension doesn’t appear in my Safari toolbar, and it is installed. When I close and reopen safari, it reappears, but just for a few seconds; after that, it dissapears again.
Something else I found is that the ‘Open Script Folder’ now appears as an Icon at the top of my safari browser, together with the icons of other apps I use, and with the internet, batery, date/time icons, etc… The icon looks like an old document, a scroll.
I never told my computer to show up the Script icon there. I actually have no idea what is a Script. I just realized it might be connected to DT (and after that, to CleanMyMac), when I just spotted the same Script icon when I had DT opened.
I’ve tried to uninstall and reinstall Clip to DT, but I can’t. It says I should deinstall DT as a whole.
So I wanted to ask what any of you experts would recommend me to do, both with the Script Icon and Clip to DT; and also what do you think about using CleanMyMac.
Thanks a lot.
